Form 3+
Flawless Prints, Every Time
Scale prototyping and production as your business grows with the Form 3+, an affordable, industrial-quality 3D printer that consistently delivers.
The Next Generation of Industrial 3D Printing
With advanced Low Force Stereolithography (LFS)™ technology, Formlabs has completely re-engineered resin-based 3D printing to drastically reduce the forces of the print process.
25μm
XY Resolution
250mW
Laser Power
25 – 250μm
Layer Thickness
14.5 × 14.5 × 18.5cm
Build Volume
Low Force Stereolithography Technology
Pinpoint Precision
The custom-designed Light Processing Unit (LPU) inside the printer uses a compact system of lenses and mirrors to deliver accurate, repeatable prints.
Crisp, clean features:
The high-power-density laser is passed through a spatial filter to guarantee a clean laser spot.
Improved part clarity:
With LFS technology’s improved layer registration and surface finish, translucent materials print clearer than ever, right off the printer.
Materials
Switch seamlessly between a library of general purpose and specialty resins with a cross-compatible cartridge system.
Formlabs material library contains 25+ materials which are divided into following groups:
Standard
Engineering
Dental & Medical
Jewlery
Post-Processing Solution
Form Wash
Form Wash
While you’re away, parts are precisely agitated in IPA, getting every nook and cranny perfectly clean.
MORE
Form Cure
Form Cure
Once the chamber is heated, 13 LEDs trigger the post-curing reaction, bringing parts to their maximum mechanical properties.
MORE
Software Solution
3D Printing Software – PreForm
PreForm’s automatic algorithms set up your print’s layout, orientation, and supports, so anyone on your team can print successfully without specialized training.
Expert users can manually adjust a variety of parameters, such as support density and size, to fine tune results.
Design your model in standard CAD software, then import the STL or OBJ file into our print preparation software, PreForm. Get your model ready in minutes, upload to your printer, and let it build.
Follow your actions on Dashboard
Use your online Dashboard to manage printers, materials, and teams.
Manage your inventory of materials and resin tanks so you know when it’s time to replace consumables.
Enable SMS and email notifications in Dashboard to receive notifications when prints are completed or your printer needs attention.
Prepare your printer before you leave, then start jobs from anywhere with Remote Print.
And much more!
Interested and want to know more?
